Any one Ever Used one?
Old 04-13-2007 | 02:10 AM
bthanks's Avatar
Any one ever used one on diesel? Will It work?http://www.autometer.com/cat_gaugede...gid=3284&sid=4
Old 04-13-2007 | 02:18 AM
Rocky5.9's Avatar
Things like that are why I'm the way I am. I completely took apart most of the toys I ever had when I was a kid, just to see how it worked, and to see if when I put it back together if it still worked. Most of the time it did. I see things like that gauge....how and where does it get all of it's information?
Old 04-13-2007 | 03:27 AM
qzilla's Avatar
It uses and accelerometer inside.
Most likely you need to input vehicle weight and then they base everything off of an algorithm using the g forces produced.
It is probably neat and handy and you can use it to measure to see if you are doing better or worse but, I would not call it real data. To make it even worth using you would need to use the same stretch of road everytime. Same vehicle weight and same launch style.
I am not saying it is not accurate, it probably is "pretty" accurate but, it is all based on a formula. If you want it to show faster then you can probably enter a heavier weight and then boom, you added horsepower to your truck!
Nothing more than a different style of a g-tech! I bet every ricer in town has one in the pillar!
12valvin
11-09-2010 03:29 PM
roxxx
10-18-2010 11:53 AM
dslpwr81
03-11-2009 08:39 PM
MikeThomas
05-11-2008 12:39 PM
Nor_Cal_Angler
06-07-2007 12:52 PM
Quick Reply: Any one Ever Used one?
