another water injection question
I got one on my truck tapped into intake, its just a on or off type no progressive, works fine when the truck is empty, I can fell the truck pick up when it kicks in. but when I put my camper on and the meth kicks in the truck starts to miss real bad. in mixing meth with water 50/50. whats the deal?
DTR 1st Sergeant
Two things could be happening. One, too much water is putting out the flame.
Two, too much meth is causing detonation.
Try cutting back to 1/3 meth, retard timing a little if possible and maybe smaller nozzles.
You are going to have to play with those perameters and find what works best. Don't continue to run with that "miss"-- you could really hurt something.
Fuel pressure Ok?
Fuel filter clean?
A lot of variables but as stated, ease up on the meth usage. I don't know about the timing with your Hypertech stuff but if it's adding timing and you're spraying meth, you can blow a headgasket or worse pretty quickly. Without studs I wouldn't spray anything, imho.
Fuel filter clean?
DTR 1st Sergeant
I agree, but think it is only part of the issue which is why I phrased the response like I did.
I really think that as he needs/adds power, then there is more fuel and he gets to a point where there is too much timing AND meth and that is when he reaches the threshhold. With only one 800cc nozzle, it is not putting a ton of water out, but with that large a nozzle and not knowing the psi of the pump, it may not be atomizing well either.
My recommendation is like I said above, cut the meth down to 1/3 (maybe even 1/4), and dial back some timing.
DTR 1st Sergeant
I am not familiar with your hypertech tuner... but there should be a tune that will go without timing or lowered timing. If not, you have only two choices. First is the tone ring mod (do a search here to find it) which will allow you to manually dial out some timing or second, keep diluting the meth down until the miss goes away.
