another water injection question
I just put a 7 gallon tank in my bed, moved the pump closer to the tank ran new 3/8 line and with my two nozzles I am flowing 26 gph. the question I need help with is should I be worried about loss of pressure with the 150 psi pump?? I saw a adjustment screw on the pump does that raise the pump pressure if needed or is it time to upgrade to a 220 pump?
DTR 1st Sergeant
I don't know the proper answer to your question, but I have recently installed the snow stage 3 and running the two big nozzles (in addition to the one small mileage nozzle) sent from the factory the pump is a 150.
The distance in question (10 to 15 feet or 3/8" tubing) will not hurt you on pressure at the nozzle.
The adjustment on the pump does not change the outlet pressure, it changes the off dead band.
ok I have the pump mounted under the bed below the tank so maybe 10 feet of line to push the water through.
gsbuick65
17
08-03-2009 01:41 PM
GOT BOOST?
04-18-2009 10:05 PM
jdpiii
06-19-2008 07:34 AM
Jezzhuntin
08-25-2006 02:51 PM
deezulsmoke
08-29-2005 03:04 PM
