Another Smarty question, sorry.
I have been trying watching the posts, but still have a few unanswered questions concerning the Smarty. Sorry to beat a dead horse, but the Smarty threads are getting long and difficult to mull through.
1) What settings can you safely run with a stock fuel system, turbo, and clutch?
2) What type of boost will I likely see?
3) Is there a way to limit the boost to 35-37-40 psi? I have a plastic capped intercooler (I have a metal one in the box, but was going to wait to put on until my major hp mods)
Thanks for the help. Tac
I don't think you'll get much more than that out of your turbo with your mods and the Smarty anyway, so why not install that new aluminum 'cooler and give the Smarty a whirl?
i think the smarty says its safe for a stock clutch @90 hp. but i depends on the condition of it currently, if its on its way out, it might start slipping pretty quick. and as far as i know, there is no way to limit the boost to the range your wanting. on my truck it will hit about 46 psi. no problems yet
brett
brett
2) On lvl 3 (60hp) boost is same as stock, could be more above level 3?
3) Dont think this is a concern unless you're on higher levels or use a boost fooler.
jmccart
11-22-2007 07:43 PM
Dwitt0187
10-13-2007 03:21 PM
D.Wiggs
57
11-09-2006 03:54 PM
Ramified5.9
05-12-2006 01:19 PM
