View Poll Results: Manual Arm or Automatic Arm for Turbo Timer
Voters: 43. You may not vote on this poll
Another Commander/Turbo Timer Poll Question!
Ok, it is a pretty simple question that I can imagine will have a lot of opinions.
To set the turbo timer we have 2 options. On our end the only real difference is how much it costs to build. We can either build one that works or one that works and is a little fancier.
I will sort of describe them and then you can choose your selection on the Poll.
1.) Manually set the timer everytime you want to use it. Basically what you do is go into your menu for the timer and select either how long (time) or how cool (egt) you want the truck to be before it shuts off. Then before you shut the key off you would hit the bottom button on the Commander (just one idea) to arm it. Your settings would always remain the same you just need to manually arm it.
2.) Automatically have the turbo timer work if you have either the timer or the egt cool down function set. To make the timer not work you would need to have both setting turned to the off position or the timer is going to activate automatically in a key off situation.
I see both pro's and con's to either method. I want to hear some opinions on this.
If you have any other questions please let me know.
Quad
Quad
I like how my Attitude always automatically activates the timer if you have it enabled. If you want to override it and shut the truck off sooner you just hit the brake. If i had to manually set it each time I got out of the truck - i would bet that I would just turn the key before remembering to set the timer. There's an opinion for ya.
Well the TST timer can be set either way, auto or manual. I like having the option. Mine has been on auto now since I got the upgrade.
If I had to choose, then it would be auto if a parameter was set. That still gives me the option to turn it off.
I think I see a trend! That was my gut feel as well but, I also see a lot of threads like "my truck won't turn off" and it ends up being that they set the timer up maybe to too low of a temp by mistake and then they freak out because they can't kill it with the key.
While the commander will soon be added. I have a viper system that has a turbo timer. Of course I must activate it when I want it. It would be nice to have both options. It should come as manual with the owner deciding to make it an automatic proceedure. Hence less problems with the complaints of the truck not shutting off.
Well, that is a dilema right now as well. What you are talking about is a stand alone type turbo timer. I am assuming that there are plenty of those on the market right now??
What we are talking about is a piece (as inexpensive as possible) that will add on to the Commander to give you a cool down option. Basically we already have all the EGT and TIME parameters built into the COmmander so it is just a matter of hooking to the needed wires to keep the truck running with the key off.
Sounds simple, can be simple but, we are making sure we think it all the way through.
I have the isspro unit right now, nice unit, works as advertised, I put a switch in to override the system. I would like to have something like the commander with the timer into it though. Maybe it wouldnt unlock my doors when the truck shuts off
Kevin
Kevin
You can probably fix that by changing the keep alive wire on your truck. I am guessing the wire you chose keeps everything alive. You can probably just move that to another ignition wire and stop the rest of the stuff like the doors unlocking.
Maybe I was misunderstood. Certain products require the EGT sensor to be located in a certain position for their timer to function the way they designed it. I think it would be better to have the freedom to decide for myself.
