Amsoil Bypass Kit and remote mounts?
Installed. That wire they had bolted down there routed through the gusset real good. Should have made the bracket where the filter was about an inch closer to the engine and sat up about 2 inches higher but it's fine as is and the filter clears everything. Need to route the feed line differently and trim it a little shorter but for now it's ok. Works great no leaks. Held an extra quart of oil with the EaBP 100 filter. I'm gonna put a 110 on there when I change it though.
Here is a cheap setup I have about $75 in and a piece of scrap angle iron I had laying around for a bracket. Dual filter with the option of running a bypass filter in the rear slot, if you choose . Uses standard Cummins filters. I got rid of the passenger battery a while back due to lack of room for a big air filter for the twins, so there is plenty of room.
Thanks for the info, I put a small 1/8" ball valve up by the fill cap to choke down the flow when pulling hard/reving high for a quick fix. Cable tied a large mouth gaterade bottle to the end of the blow by hose so the bottom of the truck & front of trailer stays clean but if the bottle filled up last time making an oily mess underside!! I'll post my findings & fix.
unit74
25
09-04-2011 12:54 PM
Undertaker
10-26-2009 03:02 PM
t-boe
15
08-06-2008 11:47 AM
blwnsmke
17
06-20-2008 12:50 PM
ryker
10-21-2003 11:10 AM
