Amsoil bypass
Amsoil bypass
Should I buy from the web site or try to find a local dealer.Reading old posts the unit I need is BMK21.I guess you just have to make your own lines.What size and grade are they.You would think amsoil would make a complete kit for those who want one.
You want the BMK-11. Their kit comes with about 7 feet of nylon covered line. I just went to a racing store and bought some braided stainless steel NOS line about 6 ft long.. I used the braided stainless line to run the return to the billet oil cap.
I mounted the bypass under my front ranchhand bumper.
You could buy the BMK-21 and just buy the hose a connectors separate from amsoil. For $20 you can buy the preferred customer package from amsoils website and get the discounted rate. Order twice and its paid for. You can always call amsoil and tell them your setup and they will tell you what you need.
I made a bracket and mounted mine behind the passenger headlight below the filter box. only needed about 4 feet of hose.
I see this on another link.Where do I get the complete kit from the amsoil website does not list the BMK11,BMK
By-Pass Filtration Kits will have new part numbers as well.
Old Number New Number
BMK11 . . . . . . .BMK21 Single Remote By-Pass Kit
BMK12 . . . . . . .BMK22 DUAL-GARD
BMK13 . . . . . . .BMK23 General Use Dual Remote
BMK15 . . . . . . .BMK25 Dodge Cummins Applications
BMK16 . . . . . . .BMK26 Ford 7.3L Power Stroke Applications
BMK17 . . . . . . .BMK27 GM Duramax 6.6L Applications -
This is what amsoil told me i needed for my application......
BMK-21 bypass mount kit
BP242 90 degree elbow 1/8 NPT x 1/4 JIC
BK1301 Aluminum Oil fill cap
Bypass filter of your choice
Full Flow filter if you choice
BP67 Petcock Valve (My choice for sampling pre filter)
BP251 1/4" hose if you need extra
If memory serves it comes with 8' of hose and the connectors to make your own length. I ordered an extra 8' because i didnt know were i was going to mount it at first
I use amsoil for both, the full flow and the bypass. AE080 and the 110 bypass. The bigger bypass is only a few $ more so i felt it was worth it. Plus it is an even 2qts additional to stock capacity.
Jmac
11-10-2004 07:41 AM
Lightman
05-03-2004 08:53 PM
