Amp Power Steps Install Help
I'm installing a set of Amp Power Steps but I can't find door ajar wires. Their markings are
VT - Driver Front, VT/GY - Driver Rear
VT/WT - Pass Front, VT/YL - Pass Rear
The instructions said they were located left of the steering column.
The wires are up high and to the left of the steering column. Take off the bottom cover under the column. Then look up and left. You should see a gold colored ground bolt. The wiring harness you are looking for is above and to the left of this bolt. You will see the violet wires in the bundle. Note that the vt/wt and vt/gy wires looked very similar and it was a little difficult for me to distinguish between the two. A good flashlight will help in determining the wires. There are some color pictures on this site that will help. http://www.off-road.com/trucks4x4/Pr...tegoryId=45807
It took me and my father in law about 3hrs from start to finish and that was with taking a break for lunch. The instructions are a little misleading when they say to the left of the steering column. They are more behind the dimmer switch. Hope this helps or you have already figured it out.
Thanks for the reply, WhiteMule. I did figure it out yesterday and got them installed. The only thing I don't like is that the steps take up room next to the frame rails and that's where I was going to install my compressor and air tank for my onboard air. Oh well, I'll just have to find another location for them.
So far I love these steps. I haven't had them but a week and I've had many people ask to open and shut the doors. They are cool. The second part of the answer is that they are very functional. My wife had back surgery last year and had a very hard time getting in and out of my truck. Unlike most nerf bars, they extend down and out enough to be actually useful. My wife used the term WOW! when she used them.
I was quoted the same price to have them installed. The installation is a piece of cake. I'm glad I didn't pay someone $400+ to install these. Read my first post in this thread and then take a look at the link. Also I found a way to save a few bucks on these.
tempforce, and WhiteMule,
Thanks for the info, I've seen them on a few trucks in town and they look really good. As you see I have a 6" lift and 37" tires, and my wife has to strain to get into my truck. I also live in a snowy area and wondering if they would work with all the snow and ice build up on the frame and steps.
Can't help you on the last part. Where I'm from snow is rare! However, I've heard other people say that they had no problems. I am thinking that I might install a little shield in front of them to keep the tires from potentially throwing mud on them.
I bought mine from http://www.electricstep.com and they are offering a $200 rebate on them.
Wiring help
I am not installing the Amp steps but am trying to wire light on my steps that will operate independently with each door. I have located the 4 violet wires mentioned above. And I don't know much about this, but are these wired like a positive ground or something? With the doors open and the test light hooked to one of the wires I get nothing on the test light. But with the doors closed and the key on, and I stick the test light to the wire the indicator on the dash ("door") comes on. So I've got the correct wires I believe but not exactly sure how to wire them. I know this thread is very old but really hoping someone out there can help.
Thanks in advance
Thanks in advance
diggity dodge
03-11-2008 05:44 PM
BlackSunShyne
31
04-10-2007 08:06 PM
jtharvey
08-28-2006 07:14 PM
