Airdog + Walbro 392?
I already have the Glacier Walbro 392 kit installed. Love it have 60K miles on it so far. Set at 30psi
I want an Airdog 150 for its air removal! My PSD ran so much smoother,less smoke and better mpg when I installed the Airdog. WIth the new price I want jump on it.
So...Can I add the Airdog and have it provide positive pressure to the walbro like my ford was setup? Or should I remove the walbro pump and run just the airdog.
Thanks
Thanks
when it was still warm it was 17-18psi...now that it is cold it has been pretty much 15-16psi...even at WOT it maybe drops only 1 or 2 psi and then bounces right back to 15-16psi...if you want more psi you can put in some regulator shims as well...
Austin'sDodge
22
07-30-2006 09:31 PM
streetsmoker
24
05-07-2006 12:26 AM
