AirDog Questions
AirDog Questions
Ok so I went ahead and bought an AirDog 150 30psi version. Went through GDP and also got the Big Line Kit, the fuel tank vent mod and the Stock filter eliminator. I also Got a Draw Straw V Hi-Flo from Vulcan. My question is is the line that is supplied with the AirDog a 1/2" line? I plan on going from the DSV to the airdog, airdog strait to cp3 with bigline kit. does this all sound right to yall? am i gonna need any other fittings or line or should i be good? thanks
HotRod
HotRod
If your eliminating the OE Canister I didn't think you needed the big line kit??
But on a side note I don't recommend removing the OE canister, the AD doesn't meet the f/w separation requirements for your 06.
I was told you dont need the Big Line kit and the AD comes with 1/2" lines already, especially since you are running it straight to the CP3 (like I plan on doing also)
kdbvulcan
20
12-06-2008 04:34 PM
Spooler
12-26-2007 08:55 PM
Super Googan
13
12-06-2007 04:06 PM
