Airdog 150 problems
Old 09-20-2010 | 06:22 PM
jcdevolution's Avatar
Question Airdog 150 problems
I recently changed the filters on my 150. Now the truck takes forever to start, idles roughly and has lack of fuel pressure but still runs. Maybe it's something dumb not sure but it ran fine before, no leaks are visable or anything, connections are fine. I've seen a lot of threads with people having problems with theirs too... a little worried these pumps arn't all they're cracked up to be. Any help would be appreciated!
Old 09-20-2010 | 07:39 PM
rip 112's Avatar
Does the pump come on with the key? What pressure if any does it read? I'm thinking you may have blown the fuse, check there first.
Old 09-20-2010 | 08:38 PM
Shank's Avatar
What about the pickup tube that goes in the filter. Mine almost end up in the trash.
Old 09-20-2010 | 09:23 PM
Not sure on pressure at the moment, I'll check it tomorrow. But the pump comes on as soon as the key turns over. It does run pretty loud though, says that it should be quiet. I know a couple other people who have the 150 and say it runs loud though. I'll check that filter tube too, what usually happens to them? Does it crack or something? Maybe I didn't put the filters on right but I'm pretty limited on being able to screw up a filter change lol
Old 09-20-2010 | 09:53 PM
rip 112's Avatar
If you hear the pump then its running, so like stated above i would look at the pickup tube, may be clogged. You may also be having the 1/4 tank issue if you are under 1/4 tank. Do a search on that and you will find days of reading.
dieselfumes57
14
10-09-2010 08:50 AM
CrashCade
12-03-2008 08:58 AM
O.T
174
11-03-2008 06:41 PM
dodgediesel
26
11-02-2008 01:20 PM
Ramtuff06
08-21-2007 07:21 AM
