Airdog 150/ do I have problems or what?
Old 10-17-2008, 10:19 PM
  #91
chrleb1's Avatar
You could very well need the 250 series pump.
We have 550hp N-14's with 2100#tq all fed by less than a 80gph pump.
***Verify that you are not bypassing fuel at wot.
Tim
855 cu.in. motor making 550 hp and a 359 cu.in. motor making over 950 have some different fueling requirement. N-14s are making fuel power up to 2,600, right now I'm going up to 3,500.
I see what you are thinking though.
Old 10-18-2008, 09:46 AM
  #92
chrleb1's Avatar
Bueller.... Bueller...
Old 10-20-2008, 12:44 PM
  #93
chrleb1's Avatar
Just on a side note for Airdog...
At 750 wheel the pump maintains almost 30 psi. Perfect... Until I turn it up to 950 wheel (4 psi). These numbers are on fuel with no bottle.
Old 10-20-2008, 01:10 PM
  #94
jlibert's Avatar
Good info.
Congrats on the runs this weekend, I heard you did well.
jp
Old 10-20-2008, 01:18 PM
  #95
O.T
O.T's Avatar
Erick so you hit 950 on fuel! That is very cool man. How did everything sound and perform?
Old 10-20-2008, 01:55 PM
  #96
GOT BOOST?'s Avatar
a 150 pump supported me at 780 hp this weekend and I had more but I ate my clutch alive, I did have to use pressure to keep R.P up but I don't think lift pump inadequacy was the problem, at these levels you have to use some rail increase to keep up. Jay
Old 10-20-2008, 06:52 PM
  #97
chrleb1's Avatar
Actually 958 uncorrected. It did pretty good, but I was on the rev limiter for the last 250-300 ft. So close to 10's.
Old 10-21-2008, 08:44 AM
  #98
chrleb1's Avatar
It seems that Charlie at Airdog has on open ear to this problem and has a new product for me to try when it is ready. Unfortunately it won't be ready for several weeks, but that is out of Airdogs hands. It'll be interesting to see, none the less.
Old 10-21-2008, 09:36 AM
  #100
chrleb1's Avatar
Originally Posted by AirDog
The 250 you speak of is only 8 psi. The new system has more fuel. Hopefully it can take care of you.
I hope so. It sounds promising from the flow numbers that I've been told about. I have a lot more fuel to add to my truck and I'll need something to move it. As you can see in the video, the truck has the air supply to support more fuel. My EGTs during the run were only at 1,200*.
Old 10-21-2008, 11:41 AM
  #101
jlibert's Avatar
did you do the 958# at your shop?
Old 10-21-2008, 01:07 PM
  #102
chrleb1's Avatar
Yeah, on a dynojet 248.
Old 10-21-2008, 01:25 PM
  #103
jlibert's Avatar
I gotta get down there to do some baselines, and to see that beast! Congrats man! Making the valley boys proud.
Old 10-21-2008, 01:37 PM
  #104
chrleb1's Avatar
The truck is out in Riverdale now. It'll be getting ready to change some other stuff out on it. Then it is getting a cage. In November, I'm actually heading out to join him.
Quick Reply: Airdog 150/ do I have problems or what?
