Airdog 150/ do I have problems or what?
Guest
Posts: n/a
Refer to post 14. You ecspecially should not have this problem. Need to know some info. Whether its the AirDog or your install. I know lots of people that have had check valve problems on the cp3's. Have you guys checked that?
Guest
Posts: n/a
my email address is anthony@pureflowtechnologies.com. That will insure I get your question soon.
Wise ones...not sure how I could have messed the install up.
As I said I flow tested the pump and it flows the corrects volume. I did not flow test with pressure, so I cannot confirm this.
I run 1/2" lines to both CP3's and my bottom pump is a modified stage 2.
I'm supposed to compete next week and cannot afford this PITA.
Pump sounds normal to me.
Rob
Rob
The install is not the problem. It has the down spout that was sent with it. I put a Y right after the AD and ran 2 lines up to the pumps (one for each pump). The AD is nice and quiet like they should be (like the others I've heard).
I am running 40 psi because the pumps like it. I'm not running d-max pumps, so the pressure won't mess with the bottom end. Just to let you know, the truck is making over 900 on fuel.... So i am using a ton of fuel.
Ah come on Mark.... Not normal? Okay, I'll go with you on that one.
Rob
Rob
Guest
Posts: n/a
You have mail back. Yours definately sounds like an install problem. Possible pump problem but doubtful. Answer the rest of the questions I asked in the email and it will help determine that. If your pressure is good at normal driving conditions its your install and you are getting air in the system with the surging you described.
Guest
Posts: n/a
Rob
Rob
Guest
Posts: n/a
Ok well with those kind of pressures you are cutting your volume WAY down. Have you tried running them at say 20 psi? Can you actually tell a difference in how the truck runs from 20 psi and at 40 psi? To the many people I have dealt with on the cp3 (dodge or chevy), they have not seen a difference. Why dont you give 20 psi a try and let me know what it does. Im going to guess you will not see a difference at all in performance, but will maintain your fp. I hope this can help your problem. Please let me know if these suggestions are ok with you or not. Ill do my best to help with all of you. I apologize for me absent from this website. I was unaware we were a site sponsor and Ty let me know there were a few problems going on. Thanks
How do I change the pressure in it? It was setup at 40 psi from the box. Is there a spring or shim to replace.
Actually it has been proven that increased pressure to the cp3 can increase power and help maintain rail pressure. Ask RC *** about it. I believed he picked alot of power by ramping in the pressure.
Also, if the pump is set at 40 and trying to maintain it, how would dropping the start point help. I'm getting down to almost 5 psi. If the start point was 20, wouldn't it be worse?
I'm thinking the flow rates are based on a open test. In order to flow 150gph at 18psi this would take a wack of current. Not sure this is the case, but would make sense considering my problems.
Rob
Rob
Guest
Posts: n/a
Anthony Reams
