AirDog 100 installation questions?????
Does the AirDog 100 relgulate it's pressure at the CP3 or does it have an internal regulator that does not require a return at the CP3? AirDog package looks good compaired to a GDP kit as far as simplicity and I am all about keep it simple stupid. Does it come with the 3 micron filter out the box? Is it possible to get a 2 micron Fleetguard filter or Airdog filter and what are the part numbers.
I pretty sure it regulates pressure at the pump where the return to the filler neck atleast that is how it is on mine but I have a vp truck. It does come with the 3 micron filters if im not mistaken and can be crossed to a fleet guard numbers not sure what they are right of the top of my head though.
Yep, they have a return port on the motor itself and the return line goes back to the filler neck. Derek, they are very nice and the price is right.
![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
Spooler, I developed the Fuel Preporator spin-on wire screen water separator for the class 8 truck system. Fleetguard the WS-200 for our class 8 Preporator and also the AirDog water separator. The 100 micron screen protects the gearotor pump from jamming by large particulates while allowing the fuel to flow with virtually no restriction. By the way, Fleetguard's crossover number for the Fuel Preporator water separator for the big trucks is model no. FS-1023. You probably see that in use on other products.
A very important point, I was talking with Fleetguard about our AirDog 3 micron filters. Having the filters marked 3 micron was a mistake on our part. Our Fleetguard rep told us that they should have been marked 2 micron, as that is what our AirDog StrataPore media filters are rated! Our filters will state that in the future.
Thanks,
Charlie
Thanks,
Charlie
Now I see how you us that filter as a pre filter before the pump. Help me out on how it does water seperation. Never been given a good explination. Is it just water settles to the bottom when off??????? Yea old gravity trick.
6 2 Carl
11-27-2010 09:55 AM
hoffdog
22
01-12-2009 08:39 AM
53 willys
38
11-06-2008 11:18 AM
Super Googan
29
12-23-2007 08:24 PM
