airdog 100 installation
well i got my airdog 100, gonna install it this weekend with some help. Ive read over the intstructions and seems pretty self explanatory. Is there any advice i could use? Also which connections need the thread sealer? I dont need the factory fuel filter and pump at all do I if i put the return to the filler neck?
thanks
thanks
The '03 should be a really easy install.
Before you go and take your old system apart, make sure all of the connectors and fittings in the kit are correct for your truck. The first install kit I received had the wrong fittings in it. If I hadn't checked, I would have been without the truck for a week. Also verify that you understand and agree with how the bracket mounts to your frame. I modified my bracket so I could tuck the pump up higher on the frame, whereas others have modded the brackets to orient the pump differently, and some have even made rock guards to shield the filters while off-road.
Make sure that you keep the hoses away from any sharp corners or edges.
The other thing is to have an extra filter with you in the truck at all times, just in case.
One of the better quality items out there, and I'm happy with mine. I've got about 10K on mine, and it's just loud enough that you can hear it with the engine off.
garrett
garrett
Sorry to butt in on your thread but is there a cross reference # or a way to get a replacement filter at a local auto parts store? Also, does everyone still change their filter often or do you only need to change it when the warning low pressure light comes on?
Fleetguard FF5613, sold at Diesel Manor or your local Cummins dealer. There is no auto parts store filter that I'm aware of that will fit and work properly.
Keep one on hand, just in case.
garrett
garrett
i did read in a thread somewhere that your local case IH dealer could get the fleetguard, but dont recall the number. But i dont have a local dealer.
check to see were your oe lift pump is next (to filter or in tank?) thats your first move before getting to far. if its in tank the install just got a little more complicated..
Good luck with the install, it's a little tricky getting the draw straw length just right (if you're going that route).
Pure Flow sells a Hobbs switch that mounts on the pump housing of the AirDog - it will tell you if the fuel pressure is below 5 or 6 psi - it is an option - call the company they will be glad to hook you up - about $50 I think.
As long as the mounting bracket works for you without modification - installation is straight forward - it helps to have a lift and a skinny guy to reach between the rear wheel and fuel tank to disconnect / connect the fuel line. Do tape/coat every threaded connection - if possible heat some water and soak your fuel line ends to ease inserting the metal connectors - what ever your estimate of time is; double it and you should not have any problems...
Guest
Posts: n/a
Correct. Dont worry about suction tube install since you dont have an intank pump and you have an AirDog 100. Also I would suggest getting a gauge. We do have the lights available if you give us a call. But me I would like to know what my pressure is all the time, rather then when it gets to 5-6 pounds. Filter cross numbers are as follows.
10 micron-FF5617
5 micron-FF5587
2 micron-FF5613
Water filter-FS19768
10 micron-FF5617
5 micron-FF5587
2 micron-FF5613
