AIR Intakes ?
AIR Intakes ?
Has anbody had a problem with the reusable filters (eg, engine dusted)and/or has anbody used these type in a dusty environment without problems? (AFE, Scotty, Quad monster, ect..)
I installed an afe Stage I with standard filter and a pre-filter last August. After about 20,000 mile use I order an afe Pro-Gaurd 7 filter so I could swap filters and clean the original afe standard filter. During the time with the standard filter, I switched Torque Tubes and stock air filter to turbo tubing a number of times. I always checked the intake tubing and turbo and never found any dust or coating of any kind. I switched to an afe Stage II with Pro-gaurd 7 filter after about 8,000 miles on the Stage I Pro-Gaurd 7 filter. Once again no dust or film in the torque tube at all. So the bottom line is that I am satisfied with the afe air intake and filters so far. Don't have any experience with any other diesel air intake brands.
"Air!!! the best air box"
Its a thread about 6 or 8 lines down from this one, it has tons of good oppinions that could help sway you in one direction or the other. I havent got around to ordering mine yet but I am going with the afe II when I get mine.
I stopped listening to all the HP hype a long time ago but for the the ability to clean them and reuse is worth the price.
In my sig you can see I have the Bully Dog Air intake system that has a metal heat shield to protect against the hot engine. Air in to engine and heat don't mix...
coastal_diesel
17
03-18-2005 02:35 PM
genros
03-12-2005 04:57 PM
coolslice
06-24-2004 09:16 AM
