air dog 150 right for me?
ok guys i was going to get a new lift pump from opie but im thinking the air dog 150 would be the right set up for me. im looking for no more than 600 horsepower so will this supply enough fuel and or will it be over kill right now im at about 400 so would it still be fine to run it with that amount? thanks
Get the standard Mitusa pump from Opie and dont look back.... ditched my Airdog for the Mitusa couldnt be happier!!
The standard pump is good for about 750hp so it wont be over kill for your HP goals!!
MITUSA ALL THE WAY....... Just my $.02
What he said.
If your pump is not in the tank a better idea would be to get a Raptor 100 so you can use the factory feed from the tank, then plumb the factory fuel filter inline (it has a better fuel separator) then put a 2 micron filter between it and the Cp3.
the mitusa will pull fuel through the stock canister wont it? or am i mistaken? i do want the mitusa actually i was just wondering what you guys thought
Not sure, there's a restriction at the top of the canister down to about ¼", fine for the AD100 but a bit small for the AD150, no idea for the Mitusa but I think it would be too restrictive.
Is there a return line with the mit?
Yep it pulls through the stock canister!! I have a CAT 1R-750 plumed inline before the stock canister too. This pump has no issues pulling through the stock canister.... its the MAC DADDY of LP's.... HANDS DOWN
There is KINDA a return, but not to the tank! The fuel gets regulated to 16psi by a bypass, once the bypass opens the fuel is returned back to the Mitusa.
trailinone
16
06-19-2009 04:28 PM
bridleman
09-12-2008 11:02 PM
bullrider9800
05-11-2008 05:04 PM
diggity dodge
05-03-2008 12:42 AM
