Aftermarket Turbo, & Inj. Program
I just put the AMKT turbo, & Inj. Program in the truck last night, & drove to work, & home again & I can't believe how much faster my boost builds now as compared to the AMKT Turbo/Stock Inj. program. Smoke is all most gone, & the turbo lights @ much less throttle. don't know what my EGT's, HP are yet Dyno's are hard to come by around here. It did 430/800 on the other program on Sw9. It was hard to get EGT's over 1250* too.
I take it you are liking that HTT turbo. That is def. my next mod but I will most likely be going with the 71 instead of 65. And, im about to update my Smarty as well to the 4.11 program. You are still running stock injectors though right?
Yeah. I'm still running the stock inj. I was supprised how much difference the little bit of timeing changed the spool up, & smoke. I may go ahead,& upgrade to the 71 also, but I'll run this for a while longer to make sure of my EGT's with my camper on. As long as it doesn't get too hot the way it is, I'll stay with this one the way it is.
TexSoftail
02-05-2008 08:09 PM
Ghost Ram
01-07-2008 08:09 PM
bluebull
08-16-2007 04:51 PM
doug60
03-28-2007 10:21 AM
9 sec camaro
20
08-26-2006 01:30 PM
