Aftermarket Sirius PNP unit with OEM Antenna
Old 11-01-2006 | 11:39 PM
caseyclan's Avatar
Greetings,
Before buying my new 2006 2500 CTD, I had another truck with a sirius PNP unit. I loved being able to see the artist information. Now, I have the OEM radio which has NO artist information, and its driving me crazy. I want to get an aftermarket PNP, but was wondering if anyone has installed one and used the OEM antenna? Will it work correctly? I was hoping to avoid adding another antenna on top. Comments are welcomed.
Old 11-02-2006 | 10:10 AM
Hercules130's Avatar
i to have been researching this. i was told by a local shop that i would need an antanae adapter. i never followed up on it though.
Old 11-02-2006 | 08:39 PM
torrey's Avatar
I'm running an aftermarket sirius tuner and headunit with the factory antenna. I didnt use an adapter, i simply removed the plastic wiring harness around the factory plug and it fit fine. I took a zip tie and secured the factory wire (minus the plastic harness) to the aftermarket tuner.
Old 11-02-2006 | 11:44 PM
stezlaki's Avatar
Just had a stereo installed in my truck and the stereo shop said the actual plug was the same but the plastic locking thing was different. They simply removed it and hot-glued the junction heavily so it can't separate so that I could retain my factory antenna.
Basically, what torrey said!
Old 11-03-2006 | 07:38 AM
What year is your truck? The stereo shop said i would need an adapter because i had the older 2 wire antanae and the new ones were a single wire.
Old 11-03-2006 | 11:06 PM
caseyclan's Avatar
I have seen the 2 lead antenna with OEM sirius tuner for sale on ebay. I don't know if I have that system or not, although I did find the tuner (finally) and it looks like only one lead going into it (with the plastic locking clip on the end). However, there isn't much slack in the cable, so even if I could use the end without difficulty, there doesn't appear to be much cable left to play with after it is disconnected. Did you put in a satellite system that is integrated in your HU? Does it perform well? Did you swap out the stock speakers?
willysrule
01-26-2015 12:34 PM
J OOPS
02-22-2011 12:20 AM
Utundra
12-24-2007 03:38 PM
buddy26
10-16-2006 10:28 PM
twhman
07-11-2006 01:17 AM
