Aftermarket guage light ?
i taped the power for the lights to the dimmer (even though it says not to) which is a orange/brown wire coming out of the light switch...there are two, i taped the left one...and it works perfectly...lights come on with gauge lights and dim with them.. Jason
looking at the 2006 wiring schematic, you can tap the orange/brown wire off the back of the headlight switch/dimmer switch. pin #2 is what you need to tap. there is also a orange/brown wire on pin #4 back there, but it isn't what you want
Thanks guys, I found it. I dont have a test light, I was using a multimeter and checking each pin of the plug with it unplugged with the key on looking for 12 volts.
Bigwhitey3500
08-24-2007 02:40 AM
jaredb900rr
03-28-2007 08:58 PM
bigragu
01-24-2006 11:16 AM
SilverRam01
07-21-2005 08:43 PM
