Aftermarket Exhaust compatible with "Jake" brake???
Does anyone know of a 4in exhaust system that will fit with the dealer installed Jacobs Exhaust Brake? I'm being told the HOG doesn't. And the Banks only fits with the Banks Brake. The dealer installed exhaust brake mounts directly behind the turbo. Please help!!! Thanks.
Re:Aftermarket Exhaust compatible with "Jake" brake???
I have the DPP 4" and it installed almost flawlessly. Had to trim the length on 1 pipe but the sound and fit are AWESOME!
Original Junior,
The turbo mount exhaust brakes or the 4 inch underbody inline type work and fit with our system no problem. Our turbo flange on our down pipe is the same as the factory turbo design which allows yo to bolt directly up to our system with an exhaust brake. Pac, BD, etc all work fine with the exception of the banks, they market their system so you have to use their down pipe only. Call us if you have questions, we make sure you get all the info you need.
Mark @ DPPI
Mark @ DPPI
wvcowhauler
13
04-03-2005 11:39 PM
HO Cummins
07-04-2003 12:21 PM
