AFE Torque Tube
Old 03-30-2004, 09:13 AM
JKE
JKE's Avatar
there are other threads with parts lists to make your own for less than $50. One of the machine shops could get the pipe, but I can order it myself cheaper.
Old 03-30-2004, 09:29 AM
Berak's Avatar
If someone built one that was made to accomodate the TAG or TAG II (the Afe Torque Tube does NOT), I would be the first in line. Make it stainless and it would be all the better!!!
Old 03-30-2004, 12:04 PM
JKE
JKE's Avatar
It will NOT from what I have been reading.
Old 03-30-2004, 12:28 PM
AK RAM's Avatar
For the life of me I can't remember who it was, but there is a guy here that is running the TAG with the torque tube. He said it was a bear getting the TAG inserted into the tube. If I remember correctly, he positioned the TAG at the turbo inlet and pushed the rubber elbow over it and into place on the turbo. Very tight fit. He said he checked it after 500 miles and it stayed right where it was suppose to be. If I can find that thread I'll post a link to it.
Old 03-30-2004, 12:41 PM
jt
jt's Avatar
I had a couple of 4" Stainless steel 90's bent. I only need to find some type of coupling> any ideas?
James
Old 03-30-2004, 12:53 PM
mjbarr99's Avatar
I just ordered a Torque Tube from Diesel Performance Parts for $80 along with a AFE intake. They told me it would be dropped shipped from AFE but didn't give me a time frame.
Old 03-30-2004, 02:19 PM
JKE
JKE's Avatar
80 is getting better. Wonder if he gave you a "deal" since you got the intake also?
Old 03-30-2004, 02:25 PM
AK RAM's Avatar
That is still a lot of money for a chunk of pipe and two rubber thingies. Curious if you happened to read this thread: https://www.dieseltruckresource.com/...threadid=41751
For those with the AFE Torque Tube, is there any advantage to the Torque Tube over a home made tube that we are not seeing?...other than color coordinated.
Old 03-30-2004, 02:28 PM
jt
jt's Avatar
I just ordered two 4" rubber 90's from the big truck shop, $21 bucks CND. I will put a short length of 4" stainless in between them. THis should do the trick.
James
Old 03-30-2004, 03:37 PM
JKE
JKE's Avatar
do the "rubber thingies" have a recess on each end so the ID (bore) is smooth all the way through and at the transition from pipe to "thingy" and "thingy" to turbo?
Does the AFE torque tube have this?
JKE
Old 03-30-2004, 04:03 PM
Berak's Avatar
Jt, so you won't be using the 90 deg. stainless bends you had made?
I haven't taken my stock system apart yet, but I wonder if it's possible to make a continous single piece of the proper length with the two 90 deg. bends in it? Seems like that would be fairly straight forward. Why are we bothering with these couplings?
Old 03-31-2004, 08:40 AM
Mark Craig's Avatar
Torque Tube
Moning Members,
I haven't figured out why the pricing is so high out there. We sell the Torque Tube. Currently we are out of stock on them but awaiting orders from AFE. If you need some call us and we'll get you on the list ASAP.
Mark @ DPPI
Edited by Admin
Old 03-31-2004, 09:36 AM
jt
jt's Avatar
The distance from the turbo inlet to the air filter outlet is only 10.5". It is barely enough distance to make the bends.
$89.99 is much cheaper then the $120,00 I have seen. It almost not worth th eeffort to make it myself.
James
Old 04-02-2004, 09:57 AM
Car_nut57's Avatar
Torque tube with TAG
We have had a few customers fit the TAG with the torque tube, but it is difficult and does not lend itself to the same confidence level and easy of installation as with the stock hose. We have heard of a couple of instances where when the torque tube was installed it created what was described as turbo cavitation. This issue was resolved by the addition of the TAG. I have tried contacting aFe several times about working with them to mold the elbow differently to incorporate the TAG into thier Torque Tube with no response.
Quick Reply: AFE Torque Tube
