Afe Pro Guard 7 drop in vs BHAF
I think you will only find opinion on this (no real facts). I went BHAF because my factory filter got dirty really fast. I think it is because you are moving so much air volume across a little surface. Also after owning K/N filters (on my jeeps) I am never able to get them cleaned and oiled properly. So it is a BHAF for me and it even has a 1 years warranty??? ...
I think the PG would help but you will probably have to open up the air box, with my set up I can go back to stock in about 5 minutes if needed.
Good luck,
Dave
Good luck,
Dave
Thanks, I have a 4 in. hole in the bottom of the air box with a outside clothes dryer vent sceen in it to keep mon ant objects. I had read about the BHAF and was curious abolut how it would compare there are alot of different opinions on the drop in filters.
Try PMing AKRAM. He started a topic about a year or so ago where they were discussing air filter flow rates and honestly it got way too technical for me but there was a lot of info that will answer your question....
I just dropped in a PG-7 this week. I will be interested to see if it makes any difference. I went with it because AFE shows it to flow a little better than stock paper yet clean as well as paper (or better). Time will tell!
wreedCTD
13
04-26-2007 10:55 PM
diesel_work
10-08-2005 01:25 PM
dwhite
03-02-2004 06:16 PM
AK RAM
01-22-2004 07:09 AM
