aFe Magnum Force Intake System w/Pro-Guard 7??
Unless I hear negatives before tomorrow afternoon, I am going to pick up the following:
aFe Magnum Force Intake System w/Pro-Guard 7 filter Dodge Cummins 2004 5.9L 325 HP/600 lb-ft H.O.
Torque Tube Kit (Stage 1 Upgrade) 2003-04 Dodge Cummins 5.9L
Does any with a 600 have problems with this air intake system?
Thanks for any comments.
John
John
Re: aFe Magnum Force Intake System w/Pro-Guard 7??
I just installed this exact setup last night. Make sure you remove the rubber "bushings" that the stock airbox sets in (you will see). I had to remove the hood padding and trim it because the hood will not close properly leaving a noticible gap between each side. Easy installation, clear instructions.
The end result: Holy cow! It's flippin LOUD!! You can really hear the turbo whistle, and I found throttle response to be improved. Without the hood padding installed (gotta put it back in) and the radio off, the whistle can be ear pearcing at low boost/light throttle - but I am not complaining! With the radio on, it is not bad whatsoever.
FWIW, I have removed the silencer ring.
Be prepared to have people stare at you as you drive by, as you *will* be noticed.
Cheers.
Cheers.
John
John
PG 7
RamWheelsBy4,
We get great customer and distributor comments all the time with the Pro Guard 7 and Torque Tube system, you will be very hapopywith it. Give us a call if you need any questions answered.
Mark @ DPPI
Mark @ DPPI
Re: Re: aFe Magnum Force Intake System w/Pro-Guard 7??
Cheers.
Cheers.
I picked up the aFe Magnum Force Stage II for 2004.5 325/600 with standard filter & pre filter today after work. I also got the Torque tube, I know that a piece of 5" PVC would do the job, but it wouldn't look purty.
I also stopped by the Predator Power local dealer and now have a Stage II Predator module. for 2004.5 325/600 Cummins.
I will put on the torque tube first and see what happens. Then I will install the Air Intake and filter. Then I hope that I have fun with the conservative Predator Stage II.
If I can make to the track this Sunday I will get times with intake and Predator, unless the EGT's are too high.
I want one of these, but I find it hard to justify spending $500 (Air Intake + PreFilter + Torque Tube) for an air filter. Plus, I've heard that it offers little to no tangible performance gains, but rather it helps keep egt's down for when you do get the Edge or TST.
Someone convince me otherwise that $500 is well spent on these.
djp
You are right it is a lot of money for an air filter. I do expect to see some small performance gains. At least I certainly expect to spool turbo quicker. Part of my reason is to lower EGTs for the fuel/boost box I am installing. I want to play with my truck at the track. I may be very disappointed after this weekend if I don't see a noticable improvement. If it helps any at all with normal MPG then another benefit. I keep pretty good records and will know in a month or so if there are MPG gain or not.
Besides I am getting way to old to worry about money. Found aFe Filter Kit and torque tube online at www.kensperformancesolutions.com for under $400. Maybe you can find lower.
TORQUE BEAST
06-08-2008 07:53 PM
dodge6speed03
03-08-2006 10:50 AM
CETANE
05-10-2005 07:19 AM
RamWheelsBy4
09-18-2004 02:23 PM
kelley15
07-25-2004 06:12 PM
