Aero 4040 Muffler
i hauled a toyota land cruiser for 2500 miles... it has bad drone while towing you almost needed ear plugs... we were going 80 mph though
but for straight driving it is great nice sound and quiet in the cab at idle
I have the AeroTurbine 5050XL and installed it 4 inches behind the cat as it states in the install instructions. The dorne was BAD, right under the passenger' seat. I called AeroTurbine and was told to install it as far to the rear as possible, under the truck bed, back more than the stock muffler was. Theres no dorne while every day driving, it sounds excellent, when towing, starting off from a dead start, when pulling hard getting onto highway, there is some dorne, not too bad, once you get up to speed towing there is very little dorne while towing
I was given the same advise, but can't figure out how. Did you put a large hanger U-clamp on the 4040 itself, what size, 8 inch and where can I get one or two on line? Any advise would be helpful, thanks.
I picked up a 6 inch muffler clamp and 2 hangers. Where I moved my muffler to the rear as far as possible it is centered under the two frame hangers that held the rear of the stock muffler. So my plan is to place the 6" clamp dead center on the muffler and make a "V" with the two hangers. Hopefully with a clamp around the middle of the muffler it will be solid enough to cut-out all the drone.
That is not what the product info says:
http://www.aeroexhaust.com/diesel_muffler_4040.html
Perhaps you are referring to the 4040XL?
http://www.aeroexhaust.com/diesel_muffler_4040xl.html
01350banshee
03-04-2011 10:12 AM
rynojr4644
06-01-2009 12:34 AM
eightball
03-19-2007 07:24 PM
01350banshee
04-09-2005 11:40 PM
