aem dryflow
aem dryflow
can anybody who has these filters tell me if you like them .I like the non oil better. did you get any better mpg? and did it help in the performance area a little? thanks kully
I've got the AEM Bruteforce. It whistles loud. Can't tell mpg gains. I insulated the tube between the filter and the turbo. That thing would get so hot, you couldn't touch it.
The air filter itself is great. It seems to flow better than my BHAF, Scottie III and S&B Factory oiled filter. I don't really like the rest of the setup. I feel that if the metal tube heats up then the air inside will also heatup. I purchased the S&B system and slightly modified it to accept the Dryflow air filter. I then added the PSM/coldair intake underneath the S&B Box. What a combination.
yes nb64 I read some of your posts on you combination .I like the non oil filter and I also looked at the s/b looks to be made well.any mpg gains and performance ? and what did you do to make the aem filter fit inside the s/b box
It was fairly easy. I used only one bolt (near the motor/battery side)to secure the box and enlarged the hole on the inside of the box. Then I put everyhting together and pivoted the box to point that the dryflow was not compressing. Since I added the cold air intake hose to the bottom of the S&B box the pivoting also allow me a tad bit more room for that.
I have a full set of gauges and kept testing each one of my filters boost/egt. I have an area of highway that I travel daily. I marked the mile post with the egt readings and boost numbers. They are all very close but the dryflow seemed to keep the lowest egt and boost numbers on this slight incline. The numbers are only within 50 degrees
(egt) and a pound of boost or so. Of course headwind and such could easily effect these numbers. It was the dryfilter idea that keeps the dryflow in place now.
Mark,
You might have something there! The filter minder gets close to the red every time I reset it and drive again. This could be because of it's position inline, but I'll watch the boost max tomorrow when I drive my daily 120 mile round trip. Will report back....
Cheers
Mike
Cheers
Mike
Originally Posted by Mark Craig
trik396,
Do a search here and at TDR there were a number of folks that reported lower boost readings due to restriction on the dry flow filters.
Mark @ DPPI
Mark @ DPPI
tufamc
04-23-2008 03:08 PM
trik396
19
03-26-2006 06:26 PM
piperca
03-20-2006 05:33 PM
