Adjustable wastegate on early 07 Cummins?
Just curious if you can adjust the wastegate for higher boost on an early 07 dodge cummins stock turbo? Do you simply turn the actuator rod like you would on aftermarket turbos?
The easiest is via a programmer or chip since the turbo is electronically controlled. Otherwise you can shim the waste gate actuator from the turbo house with washers. You can do a search for waste gate mod for more details on the shimming of the actuator.
Can he not shut it off with his edge? I know he can set an alert notice with his edge. But what about boost increase? I thought the edge came with a boost fooler ?
Hmm... thats the first I have heard that. When my WG open and I am empty it holds at 28-30, when i am loaded 30-32....
77machomopar
20
12-11-2009 10:37 AM
AH64ID
02-01-2008 08:56 AM
CACalomino
20
06-26-2007 07:19 PM
bigwheels94
04-19-2006 10:33 AM
MoparRiggan
10-13-2005 11:54 AM
