Adding a Dual Feed Line ON a Stock CP3???
Old 02-26-2007, 07:53 PM
  #31
Jeff K's Avatar
Originally Posted by abc4yew
I have one sitting in the closet.....
If you need someone to test it for you...let me know
Old 05-26-2007, 08:51 PM
  #32
megaboom's Avatar
so anymore word on this dual feed line?
Old 05-26-2007, 09:49 PM
  #33
Luvnacumns's Avatar
I'll let you know when I get mine!!!
Old 05-27-2007, 02:09 AM
  #34
megaboom's Avatar
thanks buddy!
Old 05-27-2007, 08:31 AM
  #35
abc4yew's Avatar
Hmmm, somehow I became unsubscribed to this thread so I lost it... Both ends of the hose are the same...they are female and fit onto the CP3...There is one adapter and it goes from the CP3 size to the rail relief valve size...Chris at Relentless has a Y that allows for a second feed line and the rail relief valve to be used...I think that this would help the truck to run smoother.....I don't think a picture would help make it easier to make one. The feed line is 33 inches fitting to fitting... and no I haven't put it on yet and apparently it is very difficult to get it tight enough not to leak...The hose is Parker Polyflex 2440D-03V37 4.7mm 3/16" 6033 Germany QC36169784.
Hope this helps. And Yes I'll probably try it when I get the other 11 things I need to find time to do on my truck...
The super cp3.4 is a CP3 that is 230%larger and flows 230% more fuel than a stock CP3.....4k or so from II. ks
Old 05-27-2007, 01:01 PM
  #36
XLR8R's Avatar
I looked into making a mechanical rail pressure kit last year, but it's just not feasible due to the price & availability of the parts neeed... the HPCR fuel environment is way over typical hydraulic territory into the water-jet cutting pressure range!
Someday there'll be a hose/fitting assembly that won't be so hard to keep sealed...
Old 02-07-2008, 07:16 PM
  #37
megaboom's Avatar
so does anyone have pics of the fittings for this duel hose? or know of another company that makes them?
powerstrokin03
02-15-2007 04:29 PM
EQUIPPRO
02-14-2007 09:04 PM
dodgeboy59td
01-06-2007 11:43 AM
deezilpwr
10-22-2006 12:45 AM
Quick Reply: Adding a Dual Feed Line ON a Stock CP3???
