Adding Cruise Control ?
How do you disassemble the steering wheel on and late 04 2500 ST? I couldn't find any screws behind the steering wheel and don't want to break anything.
Thanks, Dave.
https://www.dieseltruckresource.com/...threadid=36229
Thanks, Dave.
NV. You need to start by removing the upper and lower shrouds on the column (the two plastic peices in fron of the wheel). Once you remove those, there are two bolts (left and right) that you will need to remove so that you can remove the cover on the wheel. As with anything, you should disconnect your batteries, just a precaution so that you do not deploy your air bags. Hope that is a start for you.
Dave.
Nate-03 D
44
05-21-2007 09:30 AM
trophystock
07-06-2006 06:28 PM
