Acetone improves MPG!
I dunno'...What do you guy's think? Anyone tried this? Seems very logical from a chemistry perspective....Maybe help with our injectors??
http://pesn.com/2005/03/17/6900069_Acetone/
--D
--D
Quick update: The guy's over on Pirate4x4 are showing some real number increases (in gassers anyway)...I haven't checked yet, but there suposidly is a thread over on the Diesel-Stop about this. Some are showing 4-5.5 MPG increase!
Check the Pirate posts at: http://www.pirate4x4.com/forum/showthread.php?t=341237
My dad is a chemist woth Dupont and agrees that the Acetone can be a catalyst to aid in clean (hence efficient burning of fuel....gas or diesel)....his concern was that it may attack certain materials in the fuel system....interestingly he stated that glass is about the only thing he is sure of that acetone won't attack......I have an old Jacobsen F10 Mower that uses an industrial gas Ford Engine and in the instruction manual, it states that if gas is allowed to sit and varnishes up the carb it is OK to drain the carb and filll it with Acetone and then drain it out after letting it sit for awhile to dissolve gums and varnishes....I suppose in the old carbs it may be OK to do but I am not sure about rubber lines / parts etc....Anybody out there wanna try it and report on this?
Administrator / Scooter Bum
From the end of his post,
Disclaimer If you do harm to yourself, your vehicle, or anything within 3000 nautical miles of yourself it is your fault. These items are posted for the fun of it and in no way constitute advice or directions or recipes.
...........works fine in my lawnmower
Yea, it eat's paint too...
But the quantities we are talking about are 2oz/10galsl...Or .003 by volume...Not enough or start desolving your tank, or anything else for that matter.
I would say that if any additive added that much fuel economy then it'd already be out on the market and well known for doing so.
As stated earlier in the thread, a Chemist from Dupont knows about the potential benefits of Acetone... dont you think most other chemists in the world know about it too, then? And have already experimented with it?
idea , place the mixture in a glass, plastic, and metal jar. set it in the garage for some time and see if there is anything going on. in the glass jar, cut a small piece of fuel line and drop it in.
Back in my motorcycle racing days I used to use 404 accitone per gallon and also added 1 oz of 2 cycle oil to my bike on race day, it made a huge difference on performance and I had no ill effects from it, all fuel lines were the clear plastic stuff, the bikes were all 2 strokes.
Cheers, Kevin
Cheers, Kevin
Originally posted by doomgaze
If it sounds too good to be true, it probably is.
I agree doomgaze, I just wonder how many of them have been paid an insane amount of money to come work for a company. Were the company can keep an eye on them and put them to good use.
