A5000 and towing???
Old 05-31-2008, 11:39 AM
hotrod929's Avatar
A5000 and towing???
Thinking of upgrading to an A5000 and some sticks with a predator. THe truck is a 05 2500 with a 6 speed? Is this not going to be able to tow a 33' boat? How bad will it be? Thanks
HotRod
Old 05-31-2008, 11:57 AM
53 willys's Avatar
I would PM member "cquestad" if I was you...IIRC he towed heavy with a A5K for 100K miles before his turbo let go....thats pretty impressive!! he would be the guy to talk to about DD/towing and the A5k.
Old 06-02-2008, 11:49 AM
hotrod929's Avatar
Anyone else got some experience with this?
HotRod
Old 06-02-2008, 12:31 PM
tristan21's Avatar
I dont see you fueling listed there fill out your sig. That will make a big difference. From stock, maybe, but with inj, cp3, and smarty its no problem pulling a 24' enclosed chock full of tools, probably 20,000lbs. But then again some people dont like a squalin dual disc clutch, tha whine of a big turbo, big tires, or a single stack. Those are the best parts.
Old 06-02-2008, 12:43 PM
cquestad's Avatar
I would say you are fine...with the "right" amount of fuel dialed in. You just have to drive around the lag...
Choose a grear and speed to keep the rpms at or above...above is better 2,000 rpms.
You want to have a tow fueling setting for the turbo that does not fuel as hard on the bottom as a race fuel setting or you will have more of a battle with surge.
I towed upwards of 25k many many times...a loaded 30 foot gn with 8x10 frontal area 2000 mile roundtrips at 80 mph almost a dozen times...
It gets tricky...but should be even easier with a manual.
Go for it.
king d
07-27-2008 11:17 PM
Speed Shift
50
05-29-2008 11:56 PM
king d
02-09-2008 10:29 PM
DMS1707
47
06-28-2007 11:15 AM
03dodgeoffroad1
36
06-08-2007 05:35 PM
Quick Reply: A5000 and towing???
