875+Hp Diesel only
Old 10-23-2007 | 11:11 PM
  #46
jwb600's Avatar
nice numbers! I know you were reaching for a thousand a while back and it sounds like you are very close to your goal.
Old 10-24-2007 | 12:16 AM
  #47
HOHN's Avatar
Originally Posted by Idaho CTD
Justin,
It is wastegated from the hot pipe to the down pipe using a Tial 44 wastegate. The HTT uses the factory internal gate with a spring controller.
So what's the rationale for plumbing it back into the dp instead of just dumping it into a shorty pipe aiming at the ground?
This approach would be simpler and reduce turbulence in the downpipe, but obviously it would be pretty messy when the wg pops if you are still smoking.
Thanks for humoring my questions.
jh
Old 10-24-2007 | 01:40 AM
  #48
Idaho CTD's Avatar
The reason is I dont like things to look half a$$ed and it keeps the underside of the truck much cleaner. It's definately harder to do but most things worth doing are. The turbulance will only be a problem when the gate is open and that is a very short period of time, especially on the dyno.
Old 10-24-2007 | 01:45 AM
  #49
HOHN's Avatar
Got it! Thanks..
Old 10-24-2007 | 04:39 AM
  #50
billmea's Avatar
Wow!.... gotta love the diesel.
Old 10-24-2007 | 08:12 AM
  #51
abc4yew's Avatar
So basically Tim wants to keep his boost pressure below 75psi....right now he is bleeding off the drive pressure boost coming out of the the top HTT to the downpipe to achieve this. This is alot better than putting BOV's on the intercooler pipe as when they blow the turbo can overspeed. This controls the intake boost at the exhaust....yep hard to plumb but worth it.
Nathan, I'll be calling you later on today to talk. Kerry
Old 10-24-2007 | 02:39 PM
  #52
cquestad's Avatar
Sounds like my twins...hehe. My tranny is almost back together...I am next!
Old 10-24-2007 | 03:54 PM
  #53
Don M's Avatar
DTR Advertiser
Tim,
Im still asleep from the drive back home. You did a great job. Next time lets start working on the HP before the week of the event. OK? LOL
900+ is around the corner. There is more in injectors and we found even more HP this early week with Smarty tuning. Marco is a great guy! I have a new friend. Too bad we all live so far apart.
life is good
pwrtripls1
01-17-2008 02:20 PM
Don M
30
09-22-2004 01:26 PM
gblsmoon
04-08-2004 12:19 AM
JaMan
03-07-2004 05:24 PM
Don M
24
07-25-2003 12:40 PM
Quick Reply: 875+Hp Diesel only
