67 lbs per minute!!
#31
I have heard a lot of problems witht the wastegate hear lately with 4.5 and 05 turbos. I wish there was a way around the electronic act.
#32
Sorry been away for awhile...on vacation....I based the numbers on my numbers and then modified them using the ratio of the volume of the exhaust turbine chambers....assuming the turbines take up the same volume these "estimates" should hold up....the only way to flow more air through a housing with similar turbines is to have less occupied turbine space....as in a bigger housing. The Super B is a 57mm on the small side the Holset is 62mm. The difference in mass flow considering the size of the inducer is amazing for the super B....it is a very efficient little turbo and it lends itself much better to twins than the stocker because of the housing size.... ks
wap
08-10-2008 09:18 AM
Great_big_juan
10-01-2007 01:01 PM
