64mm vs 62mm
Old 02-11-2007 | 05:48 PM
O.T's Avatar
O.T
64mm vs 62mm
64mm vs 62mm
If someone out there could give me some facts on the benfits of a larger compressor wheel.
My objective is too reduce egts,
1350 ft above sea level.
onetun
Old 02-11-2007 | 05:49 PM
Syndicate's Avatar
what are you doing with your truck? Towing?
Old 02-11-2007 | 05:59 PM
O.T's Avatar
O.T
Yes I tow a fair bit for liesure.
Is 1300 f for a period of 5 mins safe?
Old 02-11-2007 | 07:24 PM
Syndicate's Avatar
the problem with high temps for longer periods of time is even if you dont blow the head gasket you may end up with loose valve seats. Lower temps say in the 1000*-1200* range would be more of an ideal range. that being said I hit 1400* for a a few seconds all the time. If you want to set up the truck to tow really well a 62/12 or a 62/14 would be best I would think. a BD super B would work reall well too. All 3 will work well up too 450HP towing. Im sure some others with more experiance will chime in. Im just relaying info that I have read on here on the turbos.
Old 02-11-2007 | 08:01 PM
wap's Avatar
wap
I dont know that steppin up to a 14 wouldnt be a better idea.
Call Paul at HTT tomorrow and see what he says.
Old 02-12-2007 | 12:14 AM
Forrest Nearing's Avatar
yeah, if you're towing, more turbine might help...
but... if you're towing? best thing you can do is twins!
Cole_56
07-29-2008 09:00 AM
C/PRD/
06-16-2008 08:28 AM
mainer
09-20-2007 04:43 PM
PourinDiesel
0
11-27-2005 04:53 AM
