62/17-71 HTT turbo, have not seen that before
62/16-71 HTT turbo, have not seen that before
What is up with this turbo? I have seen the 62/12's and 62/14's. What is up with a 62/16?
http://cgi.ebay.com/ebaymotors/ws/eB...211653317&rd=1
You can get the HTT series in the stainless exhaust housings either 13 cm or 16 cm. I have the HTT 62/71/13ss. The 16 cm carries the same 71mm wheel but it just cools better but does offer more lag.
Well....I didn't do one part at a time so I couldn't really tell you. I put on my first turbo (HTB2), the manifold and the Arc Flow intake horn at the same time. What I can tell you now is that my HTT 62 spools like stock or faster and that's with stock TQ management. I can also tell you that I would be nervous to hang the SS turbo off of the stock manifold. The weight difference is incredible.
Yea, I think I am gonna get one (ATS exhaust manifold) just was curious of the results. I am perty close to stock spooling. When I pull heavy is when I would like for it to be better. We'll see.
Oh really, on my truck with my box turned up all I can get it as far as EGT wise is to 1250-1300. With the factory turbo I could get to 1400 with ease. If I throw more fuel at it I would expect it to be higher but the Quad Std. box have always ran a little hot..... My boost pressure is only set to 40 PSI so I have more room to play.
O.T
16
01-14-2008 02:47 PM
bigragu
04-07-2007 12:07 AM
Bobcat698
11-08-2006 11:20 AM
