54" Boggers plus Unimog portals
#46
#47
Just to giva an idea, this truck is a stock Unimog 416, with a roll cage instead of body work, otherwise it's stock everywhere else...
http://www.youtube.com/watch?v=_Vmwb...eature=related
I know the guy that built that Mog. His name is George real nice guy and the Mog is sick.
#48
the comp guys get low gears in their t-cases...they seem to do just fine with 25"s of ground clearance and a ford 9" with the 3rd member mounted on the far outside...they only run 37-39" tires too.
I really like my portals you dont hardly need to worry about what under you..its just point and go.....the comp guys can build burly easy to work on and find parts 60's and 9"s tho and they dont explode when the bounce all 4 tires off the ground and come done on sand stone full throttle
I'm not a comp guy so I dont know...I bet there is some lurking in the shadows here..but thats my guess...those comp guys run pretty burly engines too...some of them have the higher geared transfer cases and they still kick butt...
PS I wish I would have got those big 406's those are pretty dang sweet axles
a. The nature of the courses. Seems they are into the steeper
hill climb type course than the big rocks these days.
b. Weight, most of them are 3000 lbs or less, easy to drag a diff
at that weight.
c. Stickies. Those tires stick like glue, even if they are only 37's.
makes for some SICK lines that the rest of us could only dream about
(and makes it easier to clear a std diff).
#55
PEAKSTRYDE
10-11-2007 04:20 PM
