5" Pro Comp Lift
5" Pro Comp Lift
I installed a 5" Pro Comp Lift kit last week. It took about 12 hours by myself. The only problem with the installation was one of the OE Cam bolts on the lower control arm was seized in and had to be cut off. The instructions say to use new ones anyway, but they don't send them with the kit, so I ordered them next day from my dealer. Other than that, everything went pretty smooth.
I highly recommend this lift. It is a spacer lift, which some don't like, but it also has way more to it than any other lift out there. It completely changed the front end steering system by giving you and new tie rod and drag link setup which ties the front wheels together with the tie rods and the drag ling attached to it. They also include an adjustable track bar as well as a track bar relocation bracket, so you can get everything set up perfectly. The rear includes a 3" aluminum block spacer.
I have the finished product pics in my gallery. Now for some Toyo M/T's
Had mine on for about 4 months . works like a charm . I have a dual front shock kit on order , they weren't available when I installed mine.
Looks good Jeff
Looks good Jeff
crossy
10-18-2007 08:48 AM
PEAKSTRYDE
10-11-2007 04:20 PM
mjbarr99
17
04-08-2005 10:12 AM
