5 Inch exhaust Y-Pipe??...
Does anyone have any idea where i can find a 5 inch y pipe to make my truck duals???? i cant seem to find one anywhere. i can find the y-pipe used for stacks but i need more of a collector type, where they come out almost parallel with each other, as opposed to 90 degrees... any help would be greatly appreciated... thanks a lot,
Jared
Jared
I think it is 5" all the way to the y-pipe but then it turns to 4" duals. I know the Banks kits do the same; they are 4" from the turbo and then turn into either 3" or 3.5" duals.
yes from the turbo back to the muffler is 5". but out of the muffler is 4". I know cause i have a kit that is the same. Yea are most deff. goin to have to fab it cause they dont even make 5 in tails. The reason is the drivers side pipe. with the 4" on my truck its a pain. almost had to take the gooseneck plate off. But i went on ahead and raised my truck back up and hung the pipes a lil low...so good luck.
well i just did a search for you an there is a guy on here with dual 5 in and its made from flex tube. i think his name is luis garcia. only thing im not sure of is the fact that he cant put his spare under the truck! Not my cup of tea!
ouch... i def dont want to eliminate my spare unless im at the track lol but i really didnt get a chance to look at it too close, im sure i can figure something out... im looking for dual 5's bc nobody ive seen has it... nowadays, we have to do about anything and everything to be different considering the spread of diesels!!! lol im sure youll know what im talkin about... well ill do a some more searching, if anyone finds anything else, lemme know.. thanks
inlinekeith
17
07-18-2007 05:37 PM
big_bear_92007
41
05-18-2007 08:11 AM
caleb c.
12-29-2006 10:14 PM
cumminsdriver635
22
03-19-2005 05:09 PM
