42psi Boost
Unless you have that software on your Smarty...you have 32psi.
that's strange, i downloaded it before christmas, dyno'd the 26th and set my wastegate at 50psi. hmmm. quite sure that the new smarty programs for aftermarket turbos do fooling.
after reading my latest post on this thread, it seems that I may have come across slightly sarcastic. Sorry
The smarty programs for boost fooling have been available from their website for about 2 weeks. they work great. they work so good, i had to readjust my wastegate setting of 47 psi when it went way over 50. the combination of the fooling and extra fuel will necessitate a readjustment.
I was just unaware of the release date, I knew it was in the works.
No other programmer but the Smarty does this now...good job Marco.
it is fantastic. there are several levels of torque management, several different programs for combinations of mods(such as stock injectors, aftermarket turbo, after injectors, stock turbo, aftermarket everything, timing). the works. and about the only 2 problems i have had since adding the smarty are:
#1 Traction, these tires aint cheap!
#2 The burning desire to drive this truck constantly!
I have changed my filter about 3000kms ago, I know there are different ways to put them jumpers on in the box itself i had them off set it back to 50hp,(but i never installed the chip) then i set it back to 70hp and then installed it now 32psi.. mybe i installed them in the wrong place.??
I was going to stack it with the bully dog triple dog but then i blew an injector, crazy larry hurt my baby!! runnin' er wide open for 400kms..... the whole way....
\Drumheller alberta to edmonton... now i don't have the bully dog no more so i set the ez back to 70hp..
HOHN
45
10-08-2005 08:51 AM
triplenickel
08-23-2005 04:01 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
