4'' to 5'' - EGT drop while towing?
A bigger flowing intake makes more EGT difference. 4 to 5 inch has a lot bigger volume potential but at 20psi intake you are probably making 25 to 30psi of exhaust pressure so 4 inches is tons ...that said .... I have a stock downpipe to a 5 inch short side exhaust and I run very cool...and loud....Towing....I am louder than anything other than a Harley with a blow pipe at full throttle. ks
yikes, that's loud!! jm, i would say try the whistler intake but looks like you already spent some money on a K&N. What size piping does the K&N use? The whislter uses like 6" and pulls a great deal of air in. I guess you could try to modifiy your K&N to pull cooler air by shielding it more from the hot air around the motor...
FWIW, on my '93 I went from stock 3.5" with MagnaFlow muffler to full turbo-back 4" with straight through Donaldson and saw no difference in EGT's at all. I was sure going to a 4" downpipe and exhaust would lower EGT's but it didn't.
The stock 4" can support 500hp no problem.
That was from stock 4" with an aftermarket muffler. But the 5" system's I've had bell right at the exhaust elbow so it is truely a 5" system.
Very true!!!
RamMan05
Your 05 does have 4" from the turbo back from the factory. The silverline muffler that I used to have was quiet (actually too quiet for me). No noise in the cab and only slightly louder outside.
I have no cat and the long Nelson or Donaldson (forgot which). Exhaust tone is like stock, no exhaust noise. I actually want a tad more exhaust noise. I like to hear the motor a tad. Now, the megacabs have a straight through muffler/baffle right after the rear axle (FYI).
so the 4" exhaust would be sensless to go with huh? well is the 5" with the muffler decent or way too loud? i dont guess one 4" would be better then the next. i already did away with the muffler doing away with the muffler and the cat would be a bit much lol ive heard one of those. any info is greatly appreciated thanx
pirlbeck
04-03-2007 02:46 PM
suttonbeeman
12-20-2004 06:41 PM
