3rd gen Max Flow
Old 08-20-2004, 12:11 PM
AK RAM's Avatar
Scotty,
Any updates on availability, i.e., when?
Old 08-20-2004, 02:22 PM
Push Rod's Avatar
Location: Drive till ya hit a Polar Bear, then go back 50 miles
Originally posted by Gypsyman
Thanks for the quick reply Rod. Do you happen to have a link or site that shows the PE pumps? I haven't had much luck finding them on the net.
Oops, sorry for the lateness:
www.productengr.com
Rod
Old 08-21-2004, 01:33 PM
Gypsyman's Avatar
Rod,
Thanks for the link. Do you have any eliminator kits yet. My pumps going away in a hurry but it's sporadic.
-Richard
Old 08-21-2004, 04:40 PM
Top's Younger Twin
Scotty's Avatar
Just about there.
I ordered some different fittings to test before release. They were supposed to be in on Friday but did not arrive.
I will post when its ready to go.
Scotty
Old 08-21-2004, 05:46 PM
Gypsyman's Avatar
Any chance of getting one with a 90* turn down to aim it towards the new pusher pump or is there enough room for a gentle downward bend in the line?
-Richard
Old 08-21-2004, 10:51 PM
Top's Younger Twin
Scotty's Avatar
Thats what I am waiting for...the 90 push locks.
Old 08-21-2004, 10:53 PM
Gypsyman's Avatar
Niiiicccceeeeee.
I sent ya'll an e-mail with my info. Have you started a list for these yet?
Old 08-22-2004, 12:37 PM
cquestad's Avatar
I want in...
Old 08-23-2004, 03:53 PM
Muzzy's Avatar
I'd be interested in the fitting too ... Put me on the list if there is one.
-Muzzy
Old 10-12-2004, 07:58 PM
AK RAM's Avatar
Bump. That FASS sure is getting lonely sitting on my workbench.
Old 10-12-2004, 09:03 PM
Top's Younger Twin
Scotty's Avatar
I came across a small glitch.
When replacing the hardline and banjo bolts from filter canister to the injector pump, I encountered a glitch...
When I use my metric to JIC fittings, I ran into several that when tightened had the 1/8" fuel pressure tap line up with a casting on the filter housing. So I moved to the fitting at the injector pump and wouldn't you know it...I then had the tap facing the return line banjo bolt! There was no room to get the fuel pressure line on there at either site.
I am getting a longer tapped fitting made so its not as critical to have it tightened in one specific position.
I also thought about tapping my custom adapter at the filter housing...it would read pressure pre filter though and the feedback I am getting is most would like to see post filter readings.
Good thing I came across this before releasing a bunch and folks unhappy with it.
Has anyone got pictures of how they plumb the FASS and where my kit would help with it?
Scotty
Old 10-12-2004, 09:07 PM
Gypsyman's Avatar
Are the adapters available yet?
Old 10-12-2004, 09:43 PM
Mark Thomas's Avatar
anyone know what the amperage draw/output of stock pump harness, with the 4601 hp will a relay have to be used?
Old 10-12-2004, 10:08 PM
Gypsyman's Avatar
Mark,
Don't know about the amp draw but I'm going relay with mine just to be safe and using the 4601HP also. May have to call DD for an adapter though my LP is down to 4 psi at cruise.
Richard
Old 10-12-2004, 10:14 PM
Mark,
Richard
Are you going to use the summit relay kit?
Quick Reply: 3rd gen Max Flow
