3rd gen Max Flow
Old 08-09-2004, 11:05 PM
Top's Younger Twin
Scotty's Avatar
Thumbs up 3rd gen Max Flow
Finally.
This kit is 1/2" from the pusher pump to the injector pump.
It can be used with a Holley red, blue or black as well as any other pump.
I am fabricating a bracket that fits the tie down hole on the frame.
Its an oval plug with a bolt on it. Similar to what some folks are doing with a bolt and washers.
There will be three kits.
One will be the max flow lines, metric adapter and the aeroquip press on 1/2" fittings with the machined aluminum adpater to replace the factory pump. I attached a pic.
I have my prototype adapters at three machine shops to get quotes on them. Once I have this done, there will be pricing at
www.scottyairsystems.com
The kits and the Scotty Air Systems will also be available through a dealer network that will be on the Scotty site very soon.
Also, these products will be in the DTR online store!
The fuel hose I am using is the very best rubber Aeroquip hose.
This hose is actually more money then the braided teflon hose used in the 2nd gen kit. Plus it does not puncture your hand.
Old 08-09-2004, 11:08 PM
Top's Younger Twin
Scotty's Avatar
Smile
The other kit will include the fuel pressure line for a fuel pressure gauge.
Old 08-09-2004, 11:10 PM
Top's Younger Twin
Scotty's Avatar
Here is a picture of both kits with the pump adapter.
I hope to have a final aftermarket pump bracket priced by the end of the week.
Scotty
Old 08-09-2004, 11:17 PM
AK RAM's Avatar
Re: 3rd gen Max Flow
Originally posted by Scotty
.....with the machined aluminum adapter to replace the factory pump......
Talk about timing. Certainly you have read the ongoing thread about our dilemma with keeping the stock filter w/heater. It looks like it will, but just to clarify: This is intended to let us use the pump of our choice with the stock fuel filter housing?
Old 08-10-2004, 01:21 AM
Top's Younger Twin
Scotty's Avatar
Re: Re: 3rd gen Max Flow
Yes I was following that thread and I was impressed to read that others have pursued a way to mount a pump without drilling the frame. After testing a few Carters and the Holley, I am going with the Holley Blue again.
Yes it will allow one to use the factory filter housing/heater.
Scotty
Old 08-10-2004, 07:08 AM
MikeyB's Avatar
Re: Re: Re: 3rd gen Max Flow
Scotty
Scotty,
Does this adapter replace the stock lift pump on the filter housing?
MikeyB
Old 08-10-2004, 09:32 AM
Push Rod's Avatar
Location: Drive till ya hit a Polar Bear, then go back 50 miles
Re: Re: Re: Re: 3rd gen Max Flow
Yes it does
While Scott is testing with the Holley Blue pump, I'll be running PE's new 4300 (in September, when they're released).
Rod
Old 08-10-2004, 10:53 AM
cquestad's Avatar
Sweet! Can I buy the first one?
Old 08-12-2004, 09:31 PM
Gypsyman's Avatar
Scotty,
Do you have a lead time on the stock pump eliminator fitting? Also, what do you consider safe fuel pressures to feed the CP-3? Would 16 to 18 be too much over the long run?
-Richard
Old 08-12-2004, 10:29 PM
Top's Younger Twin
Scotty's Avatar
I should have quotes from the machine shops on Monday.
The Holley Blue [I prefer this pump] will run about 13 psi.
As far as I can tell, high pressure is not as important as constant volume. After some miles are logged I may have a different view...its strange how the Carters that are out there as pushers work real well and then start spiking the pressures after some power/demand is thrown at them.
Old 08-13-2004, 07:45 AM
LinearX's Avatar
Allow me to ask the dumb question since I'm so good at it.
Is this setup supposed to replace the factory life pump/filter and go straight to the CP3, or is it just going to supply fuel to the factory lift pump?
Old 08-13-2004, 08:30 AM
Push Rod's Avatar
It will replace the factory lift pump only, and keep the factory fuel filter canister with the fuel heaters for us northern boys who need it.
Rod
Old 08-13-2004, 09:55 AM
Gypsyman's Avatar
I've been looking at the Carter P4601HP, 100gph and 18 psi. What model Carters have you guys tried? I don't want to waste my time if I'm looking at something already proven not to work.
-Richard
Old 08-13-2004, 10:39 AM
Push Rod's Avatar
Originally posted by Gypsyman
I've been looking at the Carter P4600HP, 100gph and 18 psi. What model Carters have you guys tried?
I've currently got a 4601 on my 03. It appears as though I have a different model than the HP, as my idle pressure used to be 14 PSI, versus 18 PSI. I haven't been overly happy with the fuel delivery rates (at 425HP, I'm dropping 10 PSI at WOT) and it is slowly beginning to drop idle pressure now. It may be the -6 AN lines that I'm using though. Once our bracket is done, and I'm running the PE4300 test pump, I'm going to tear into this Carter and see whats giving out (bypass, rotor or motor?).
Rod
Old 08-13-2004, 10:43 AM
Gypsyman's Avatar
Thanks for the quick reply Rod. Do you happen to have a link or site that shows the PE pumps? I haven't had much luck finding them on the net.
-Richard
Quick Reply: 3rd gen Max Flow
