35x12.5x17 load E ?
35x12.5x17 load E ?
i have been looking around for a set for my dually in a mud terrain and cant find to many. toyo, BFG, and swampers is basicly all i can find and then a couple others but there load D and rated for 3000lbs any ideas. i dont tow or haul very often maybe 1 or 2 times a year usually a land scape trailer with atvs or sleds on it and some times an excavator but the trailer load is usually about max 16k. what do you think i have for options?
Better be looking for some 2" wheel spacers while your at it.I think you listed about all the tires except for Nitto.Have you considered the 295/75/17?Pretty close to the 35 you mentioned.
from what i can find it doesnt seem to make a differance whether its a 35 or 315 or in between there are alot more 33s but looks like i am going to have to settle for 1 of the 35's i can find thanks for the help
The 35s with 17" wheel seems to be an odd duck for E range. If you go to 18" wheel or down to a 33". I run 305/65/17 Extreme AT Procomps, they are 33" and E ranged. I like them a lot but they are not as tall. Check it out http://www.procomptires.com
I just put on Nitto Dura Grapplers 285/75r17 or 34x11.50r17 load E. I had to put a 1.5" spacer in but they work great! drove out to Idaho puilling my enclosed (about 6k) and im really happy with them! nice and quiet worked great in the snow too.
Did you have to shorten your truck's wheel studs to run te 1.5" spacer? What type of spacer did you run aluminum, steel. I like the look of the Dura Grapplers and everyone who gets them seems happy with them. Do you have a pic of them on your truck?
where could i find a set of 18" dually rims do they make them. i would prolly run steal rims just for the fack that you dont have to go back to the tire shop and have them dismount and rotate them
usmcduncan001
22
09-13-2009 11:15 PM
banana
17
12-05-2008 02:50 PM
ggades
01-02-2004 11:00 AM
Sarge1124
12-30-2003 02:59 PM
