3 inch front spacer with 6 inch lift?
I swithched my tuff country spacers on the six inch lift for the superlift 6 inch springs (for a better ride) and lost like a 1/2 inch in the front. It bothers me. Is there anyway to get that 1/2 back? Can i ad a 2 inch leveling kit with out changing anything/ Or could i ad a fabricated 1/2 spacer or something. Any thoughts will be welcome ones. Thanks alot all.
Your steering link going from the pitman arm to the knuckle will probably contact the sway bar mount welded to the axle at around 8-9". Its a geometry thing that as the truck goes up, the steering linkage goes up with it and gets close to the mount on the axle. Just go look at the front of your truck where the sway bar bracket is welded to the axle and picture the steering link being 2" higher at the pitman arm. That raises the steering linkage enough that it begins to contact that sway bar mount when your wheels are turned.
He'll build anything you want if you leave the truck there. Plus, he backs his stuff up. The ride was WAY better. But you could get a long arm kit from Top Gun alot quicker that would do about the same thing. My guy fabricates everything on the spot from extremely high quality metal. He takes degree measurements, resets the wheel base to factory, moved brake lines, cut a shim into the rear lift block, painted and installed it all for a very CUSTOM ONE OF A KIND setup. It just takes time. He keeps about 3-4 "magazine" major projects in the shop, then does other small things on the side when he's waiting on payments or parts. I walked in and he was airbrushing guitars for a rock band because they liked his paint work on a Harley.
I reduced the castor just enough to reduce some of the contact as a temporary fix. Then I did an aftermarket steering system and then reset my castor. Don't know what others had done.
You might be fine with no changes needed, just be aware that there may be contact and be ready to fix it somehow. You probably won't know until you try it.
One more thing, I did some fender trimming to fit my 40's on 20x10's with 4.5 bs and I'm setting at 9". If you have a wide wheel, your probably gonna need a body lift if your not gonna cut. That's just my opinion.
well i think that i am going to go with an 38 inch tire, and i think like 3.6 back space on the new rims, so i think that a little trim will do the trick, what do you think
The pro-comp X terrians come in a 38.5 I have a set sitting in my shed with the stickers still on them...waiting lol They are a nice tire tho...
I don't know for sure, every truck will sit a bit different. But I think a 38 would be your best bet. might not even have to trim.
Unruly
Thanks for the info, when I figure out what direction I want to go with this truck I might get your guys phone # from ya
Sweet looking rig, that thing is a beast....
I'm in the process of doing this myself, does anyone know if the thuren adjustable track bar would recenter my axle. I already have the drop bracket that comes with the superlift kit.
