2300w inverter install questions
Old 11-01-2011 | 04:36 PM
jkravito's Avatar
Question Pure sine wave units you would recommend.
I'm thinking about buying a 1500-3000w pure sine wave inverter for my 06 2500 CTD and could use a few pointers before I hardwire the system. I plan on using 2 ga. Or 0 ga. wire to a battery and want to keep the runs short. Probably need a breaker but what size/type? Fuses? Is a high output alternator also needed to run an inverter?
Old 11-01-2011 | 05:34 PM
jkravito's Avatar
What brands or models have you put to the test that you are happy with?
Old 11-01-2011 | 09:49 PM
06dodge4x4's Avatar
I have a 2000 watt inverter installed. Do your self a favor and buy welding cable, it's flexible and easier to work with. I ran the wire through the fire wall and under the center console. The inverter is mounted under the driver's seat. I have the regular alternator and have not run into problems running things like laptops, tools, and in a pinch the blower on my furnace. I ran AC wiring to the front and back bumpers and have one mounted in the center console. I have the DC wiring fused right at the battery with a 200 amp fuse just in case something goes wrong.
StealthDiesel
ABDTR #5
15
07-24-2012 05:18 PM
Blake Clark
02-14-2010 09:15 PM
davelinde
19
08-25-2008 08:20 PM
CtCowboyFan
12-29-2007 08:41 AM
bucknasty
09-16-2007 09:25 AM
