2006 Dodge Ram 3500 Dually
Could these codes mean it is a bad injector or something in the wiring. Please help as I have had issues in the past with another truck with bad injectors. I had them all replaced. Thank You
P/0202 Inj. #2 Control C and P2146 Bank 1 (Cyl 1-3) Shorted High or Low.
DTR 1st Sergeant
That is a wiring issue. There is the wire harness under the valve cover that connects to the top of the injectors. The wires (as the fault indicates) are divided into the front 3/rear 3 injectors.
You may have to replace that wiring harness.
the 06 has more problems with the solenoids than the wiring harness, pull the plug on the first three injectors and check the ohm's on each one, i think you will find over one ohm on the center two pins where where the first and last two have about 0.7 ohms. you can change the solenoid out in about 5 minutes without removing the injector, if you kept the old injectors use one off of them if not then you can get a new one off of ebay or amazon the wire nuts are 8mm the solenoid ring is 1 1/8" deep 12 point
Pinkston
2nd Gen All Products
02-27-2015 07:39 PM
JStevens85
14
08-12-2014 01:38 PM
N5IBM
06-03-2006 12:00 PM
pet05
06-01-2006 12:50 PM
DanTana
03-06-2006 05:56 AM
