2003 Tntr Users Only!!
2003 Smarty TNTR Users Only!!
Ok, I'm now positive that the TNTR doesn't work w/ my truck(no matter what level # or TM settings I use). I would only like to hear from others w/ 2003s that have the TNTR AND AN AUTO TRANSMISSION. I'm absolutely positive it is the Smarty TNTR program when I've tried EVERY OTHER SMARTY PROGRAM AVAILABLE and have had no other issues when shifting. The issue I have is under WOT, when downshifting the transmission will never go into the lower gear, it acts like it's bouncing off the rev limiter. If I let off the gas it will shift into gear and keep going. Am I stuck w/ the betas and regular tunes? Bob, Marco???
"Wonder if its the governor pressure solenoid."
No, Seriously! It's not my truck, it is the tuner w/ this particular tune in it. My truck will haul ***** w/ the 4.3, much stronger than the TNT, and I have no issues shifting. You know how many tunes I've tested, and I've never had this issue, it's not my GPS, it's not my tranny. If I were Marco, I would look into what's different in this tune, because it is like clockwork on every level. I could take you for a spin and make it happen every single time!
MikeyB, To answer your question, No, it happens all the time on and off the 4000rpm tune. I've tried everything on my end to see what the constant is.
MikeyB, I know, I know. I'll have a cold one soon, it's only 7am. I'm just very frustrated that I cant use this tune. If it was my truck it would be fixed already, I wish it was my truck.
It is the 5.3 which is the same as the 5.4, but I guess the 5.4 works on more rigs or the s-04, or something like that. I also had the 5.1 that acted the same way. We've been trying, I've got to hand it over to Bob, he's given me all the different versions to try. I just can't believe I've got the only one doing it, but there's not many 03 autos out there w/ the TNTR.
Don't know what to tell you. Curious if you installed a pressure gauge on the tranny port and checked between the TNT/R and the other versions and see if there's a difference.
MikeyB
MikeyB
Some softwares just do some wierd stuff. I can tell you that I can run the wild tq man of the 4.11 softwares because of serious shifting issues, I can't run the newer 4.4 beta on levels 7 or 9 without shifting issues either. I was stuck with 4.11 mod tq until I tried this TNT/non r or revo or what ever we call it. My truck actually likes this software as far as shifting goes excpet for I found 2 settings so far that make it go nuts if I need passing gear. I am not sure if it is trans or motor related because I won't stay in it long enough to try and figure it out.
Good luck tcr
Yeah, that is true, but somehow someway it has an affect. I talked to dave Goerend about this indepth a couple different times after I got my trans.
Good luck tcr
Good luck tcr
it only happens if i run my timing on 4. atleast it hasn't done it the few times I tried it so far since I took it off of timing 4. It didn't seem to get anywhere near 4,000, atleast I hope not, but that is what it did. maybe we need to talk more.
