18x9 wheels w/ 5"backspacing and 35's will they rub?
#32
They may be only 1/2" longer because that's what the website says, but the box they came in had 1" forward wrote on it and the guy said they were 1" longer. No signs of contact though under compression.
#33
#34
You are correct about them being too long! I have some issues with mine being 1" over...they are making some 1/2" one for me since I have problems with these. Basically what happens is under compression your track bar bracket and/or bar will hit your diff and maybe the coil bucket on the driver side. So unless you have about 5-6 inches of lift they will be too long.
#40
Hey Pauly.....what's your input on these Centerlines with no leveling kit on my '07.5..... 20x8.5 6" backspacing, +32 mm offset with some LT35x13.50R20 Cooper Discoverer STT's ? Should I run LT35x12.50R20's instead ?
http://www.centerlinewheels.com/whee...ehicle&data=11
Thanks !
Greg
Thanks !
Greg
#42
Greg, go for them, Centerline makes a very stout and beautifully finished wheel, The fit will probably be as close to stock as you will get and they should look great. I was actually looking at that very same wheel myself.
I agree with Pauly get the 12.50's
Fisherguy
13
05-18-2009 09:03 PM
Redneck-Express
05-01-2009 12:45 PM
PEAKSTRYDE
10-11-2007 04:20 PM
Joe T
31
05-13-2007 03:16 PM
Joe T
05-07-2007 02:23 PM
