12v source from cig lighter switched ????
Finish up my gauges (wiring) in the morning. Is the cig lighter 12v switched ?
Didnt jump in the truck tonight to try it plus the dash in apart.
Thanks
Thanks
I would use the main ignition wire along side of the steering column in the main ignition harness. This wire is a 10gauge wire that can handle the amprege your gauges require. The cig lighter would work but is usualy only rated for 15amps. I would center splice into this wire with a 16gauge fuselink. If you want to let me know if your truck has a infinity stereo i will gladly give you the wire color you need.
jon05ctd
09-05-2006 04:56 PM
Bad Ramer Jamer
01-01-2006 03:43 PM
Bad Ramer Jamer
12-26-2005 10:39 AM
Maccandy
07-13-2004 12:10 PM
