1250 rwhp on fuel only?
Old 05-06-2008, 06:23 PM
kuhkuhkyle's Avatar
Originally Posted by tritont
because it will last a lot longer.
thats not necessarily true. The engines i work on are balanced, but not to the point race engines run. There is definitely much much more than a gram difference in each rotation. And they run 2500 and 3600 horsepower for 45% of their life. Their life being 24,000 hours. Thats a ton of miles in comparison.
Old 05-06-2008, 07:20 PM
tristan21's Avatar
On what kind of motor? I think these apples taste like oranges.
Old 05-06-2008, 07:21 PM
tristan21's Avatar
Originally Posted by cmnspwr
1250 on fuel only was done at least three years ago and costs a bit more than $11k.
Trust, but verify.
Are you sure this was a common rail?
Old 05-06-2008, 08:58 PM
madhat's monkey boy...
matego's Avatar
When I was taking my performance engine class at Penn Tech we took a 350 and ran it on the dyno 10 times to get a good baseline. We then balanced and blueprinted only and we could see a definite HP increase. Blueprinting is very involved and includes lining up all the crank journals on all axis and making sure the bores are 100% true centerline. That alone will keep loads off of cylinder walls and make sure everything is running 100% true. A correctly balanced and blueprinted 350 is smooooooth! You can sit a cup of coffee on it while on the dyno running at load and there is just a little ripple in it. Sure, I am talking about gas but an air pump is an air pump. It doenst matter what it burns.
Old 05-06-2008, 09:03 PM
Reb.B's Avatar
ballance is important, cranks break, trust me! even CR ones with 3600 rpm
Old 05-06-2008, 09:42 PM
Snapoff's Avatar
I think we are talking about a 12 valve here.
Brett at Industrial Injection is not a flake.
If Brett called over 1200hp he means it......Unless Brett has something up his sleeve I assume it is either a 12v or a nitrous setup.
Old 05-06-2008, 10:02 PM
kuhkuhkyle's Avatar
its on a 16 and 20 cylinder mtu that i work on. but at 2000 rpm and 3600 horsepower youd think that a perfect balance would want to be achieved. But it isnt. There is quite a bit of difference in rotating weights on this engine. It isnt like a huge amount off, but its not by any means 1 gram off. Yes the 2 engines are comparing apples and oranges but as far as rotating weight goes. there isnt much of a difference.
Old 05-06-2008, 10:03 PM
kuhkuhkyle's Avatar
Its on an 05 3rdgen 600 engine. Fuel only claim. Just calling it as I heard it.
Old 05-06-2008, 10:37 PM
metal_miner's Avatar
Where's the "II-got-him-hook-line-and-sinker" smilie when you need it?
Old 05-07-2008, 11:13 PM
Snapoff's Avatar
Just so we are clear.....Did Brett call 1200+hp or did the owner of the truck?
Old 05-08-2008, 06:08 AM
smoky05's Avatar
My engine blew up mayb I need one of these(if its true). Cheaper than dodge wants to fix it
flatfenderjeep
04-25-2009 05:18 PM
EverydayDiesel
07-23-2008 10:46 PM
BROKER
02-27-2006 05:18 PM
Zino
16
08-06-2003 07:04 PM
dsljunkie
03-28-2003 12:05 PM
Quick Reply: 1250 rwhp on fuel only?
